GP Pitts
I'm trying to route my antenna completely inside the fuse. I have the receiver mounted under the cockpit and the antenna wire is longer than the fuse. Does anyone think there would be a reception problem if I routed the wire down one side of the fuse toward the rear and looped it 180 deg. at the rear and routed the rest of the wire along the other side of the fuse towards the front? My elevator and rudder servos are all at the rear.
Re: Spinner. If I try to use the spinner that came with this ARF, I can't tighten the prop nut. There is no room to get a wrench of any kind between the two metal supports to which the spinner is screwed on. I have a G45 gasser on this Pitts. Has anyone made some modification to this spinner or just replaced it with another make?
