GP Pitts
Mine is just about finished...... I can't wait to get this done. Man it looks good ! I hope to run the engine in this weekend and then maiden flight next weekend, weather permitting. I saw the post responses regarding the antenna being mounted inside the fuselage and then inside the tube that runs the length of the fuselage. How did you resolve the matter of it bunching up at the end of the fuselage? Did you cut a hole in the end of the fuselage and pull it through? Also, any concerns with the antenna being so close to your aft servos and wiring. Just seems like a major source for interference. Also using a gas engine. I am thinking about going outside, behind the canopy and then running the antenna up to the tail.
