RCU Forums - View Single Post - Need a USB diriver for cable
Old 05-21-2007 | 02:49 PM
opjose's Avatar
opjose
Default RE: Need a USB diriver for cable
Which "USB Cable"?
They are not all the same.
The majority are merely HID "Joystick" devices, so you should not need a driver.
Plugging in the cable alone should get it recognized as a USB Joystick Interface in XP.
Once you connect your TX to it, it should start working in XP.
If you are not having luck enable the "Microsoft HID SERVICE" in the control panel, and then try plugging it in.
