RE: gst 7.7 running hot
You could also be suffering from the half tank lean issue. There is a post on here with a couple of different fixes for this, the easiest one being the ofna fuel filter with the primer. I fixed this issue on my Nemesis by changing to a smaller tank. If you were using 20% and then went to 30% you need to reset the needles to factory and retune.
