RCU Forums - View Single Post - Dihedral for GP Skybolt
Old 02-28-2003 | 10:10 PM
MinnFlyer's Avatar
MinnFlyer
Default Dihedral for GP Skybolt
For the black sunburst, poke the yellow area to be covered with thousands of holes to let the air out. Since your scheme has so much black over the yellow, you could even cut large sections of the yellow out. Just leave about 1/2 - 3/4" of overlap and you should have no problem. In the plane pictures below, The white on each wing was put on in two seperate pieces, and the blue was added later with a 1/2" overlap.
