RCU Forums - View Single Post - Edge Set Up Help
Old 05-22-2007 | 09:23 AM
Fliprob17's Avatar
Fliprob17
Default RE: Edge Set Up Help
It says it has fully programmable functions. So you should be able to set it up for an airplane I would presume.
However, I just read through the manual and it says that the ESC can handle 2-10pole motors. The Park 480 is a 12pole motor. So I would not use it with that motor. It looks like you will need a different ESC. Castle Creations Phoenix 25 would work or you can check out Great Planes Silver Series 25amp or 35amp, or the E-Flite 25amp Pro or the 40amp V2.
What is the model number on the servos you have? And looking again at that charger, it is only rated at a 0.65 or 650ma max. charge rate? It is going to take you about 2-2.5 hours to charge a single 2100mah battery with that charger.
You will need a matching male and female connector for the ESC and the battery. I always use the Deans Ultra. Male goes on the ESC and female on the battery. The motor comes with male bullet connectors installed and matching female for your ESC if you need them.
