Intermittant problem for T7CAP
Hi,
I think I have an intermittant issue with my T7CAP transmitter.
Symptoms are:
- the transmitter sends random signals to various servos while on a flight simulator (FS One)
- I don't currently have a plane I can test this on but I'm pretty sure it's not the simulator or it's connector/cable
- the problems only appear after about 45 minutes of use on the simulator.
- in case you're wondering, the antenna has been extended to at least the 3rd section while using the simulator.
The transmitter is about 2 months old and still under warranty but I just want to know if there is anything that I could try or check myself before going to the trouble to send it in for a checkup?
Dave
