RCU Forums - View Single Post - Axe CP with gyro
Old 05-23-2007 | 10:40 AM
PilotLight's Avatar
PilotLight
Default RE: Axe CP with gyro
From what I see in your picture, you should connect "Tabs Down." I believe the brown wire goes to the black, you cut the red, and the orange goes to the white. BEFORE you do it, get another opinion besides mine as I'm not 100% sure and would hate to see you lose that gyro.
Why can't they make them all color coded the same?
Post here what the correct connections are when you find out. Thanks.
ORIGINAL: osprey21
ORIGINAL: rollingball
Follow the manuel above but get a evo 20 for the tail, the recommed esc will quit at a certain voltage and you'll end up planting it in the ground.
I have used this setup and it works very well.
Thanks for the recommendation, rollingball.
I have another newbie question....
I now have the GY240 and the EVO20 ESC, when plugging the ESC into the gyro, do the connectors go together with the plastic locking tabs facing up? Logic tells me yes but I don't want to fry anything.
Tabs UP ?
or Tabs DOWN ?
Thanks again.
