Aveox brushless help needed please
I recently picked up an Aveox 1114/4y and EZ30 controller set up. However the motor seems to be behaving strangly. I have the motor all wired up with the coloured wires all soldered etc yellow and blue are straightforward and I take it that the dark orange wire goes with the red wire from the motor. I am testing this of a seven cell 1100 sub c pack I have for a twinjet. When I power up the motor (I have to set the throttle channel in reverse as it says in the instructions to get the right stick movement with Futaba TX). The LED will light red which is normal indicating the lowest throttle point, then when I increase the throttle stick the motor gets quicker till it reaches a point and then it cuts out, it then starts and stops in a pattern every second or so it stops then powers up for about 2 seconds. If I increase the throttle to full on the engine will rev faster (and again the red LED lights to indicate full throttle which is normal) but it still keeps starting and stopping. Have you any ideas what could be causing this. . Also although the positive and minus wires are attached correctly to the battery the motor spins in pusher thrust is this normal..........Any help would be greatly appreciated.............Neal
