RE: Peakmodel Extra 260 dual elevator fitting problems
You, know, guys, I don't know if it would fit on this plane, but Central Hobbies (centralhobbies.com) has a dual elevator system (not the two pushrod system). It sits between a couple of ball bearings and allows one servo to work both elevators, but still lets each elevator half be adjusted separately. [link=http://www.centralhobbies.com/control_linkage/Bellcrnk.html]Elevator bell crank system[/link] You would have to mount the elevator servo inside where the rudder servo might go, but you could then mount the rudder servo in the tail, or just raise or lower one of the servos and have both inside -- good for those with lighter glow engines in the nose.
