RE: Silverlit 737 problem
Check that motor also, even a couple hundred RPM differance will cause it to pull to one side. I just haven't tried to pull the fan blades off yet..
new thought: you said you snapped a wing twice? Was it the same wing? If so it might be a little heaver one on side than the other.
Just a thought.
I'll post the mods I did to plane #1 soon.
