RE: plz help asap
If you're not intending to take the tire and foam completely off to dry do not boil them. Instead heat an oven to 400 degrees, turn it off and put the tire in until the oven cools. You should be able to get the tire off then. Boilg will work too but it's hard to work with a wheel full of very hot water and everything needs to dry completely before regluing it.
