ORIGINAL: jrizo1
hey guy's can i brake-in my new o.s max-21xm engine in my bad tub? this is my idea
Remove the propeler and run it only for the breke-in process.
thank you for any advice.
jrizo1
didn't you asked that question already earlier or in a different thread?
anyway, it is strongly NOT recommended. doing so does not create a load on the motor, this meens no load on the flexi, no load on bearings, no load on the con rod and danger to over rev the engine, its like everything was floating.
Do it correctly the first time, this will save you problems and headache on the long run.
Dan.
