RCU Forums - View Single Post - CA Glue Mess!
Thread: CA Glue Mess!
Old 02-28-2003 | 09:18 AM
EXCAP232
My Feedback: (12)
Default CA application on hinges
You will need to clean off the excess with de-bonder as it will restrict the movement of the surface. When you apply next try deflect the surface to one side and apply drops to the hinge until it starts to build up. Wait about 10 minutes and move the surface the other direction and then apply drops to the hinge on the other side (it normally doesn't take as many). Allow to cure for another 10 minutes and then flex the hinge for easy motion.
Two very big DO NOT try this:
1. Do not glue the hinges in one surface and then into the other. Once the glue hits the hinge it will flow to the end. If this is then applied to a plane they might come out! I was on the sticks of a new member's trainer when both ailerons parted company of the plane. Landed safely with rudder and elevator but not a fun few minutes.
2. Do not go back and reglue after later. The addition of new CA will cause a build up at the hinge line and can cause enough pressure that the hinge breaks in half causing the surface to part company of the plane.
EXCAP232
