RCU Forums - View Single Post - CA Glue Mess!
Thread: CA Glue Mess!
Old 02-28-2003 | 11:09 AM
lownslo's Avatar
lownslo
Default CA Glue Mess!
Exellant advice from EXCAP232 !! I might add that you might try buying Dave Brown CA applicators. You can litterly put one drop of CA out there by easily altering the tip of his applicator. I think the directions are on the pack. Basicaly you grab the tip with pliers and SLOWLY start pulling. You will see the plastic tube start stretching and of course, getting skinny. Before it breaks, stop pulling, and use a #11 and cut it at the skinny part. Walla !!! The tip diameter is now very small. I like the CA hinges with the slot cut into them in the middle, so the glue will be sure to get to the back of the hinge. This may not be necessary..... but it makes ME feel more secure!! .......lownslo..
Bob
