RE: Antenna Shroud - Do You Need It?
I wouldn't do it. You gain protection of the wire from the insulation covering and it helps to strengthen the wire. It's also easy to nick and damage the wire while removing the insulation of afterward. If you are that worried about a scale appearance go with a 2.4 radio system and the entire antenna will be inside the plane. The external antenna will be all show and can be anything you want.
