RCU Forums - View Single Post - Freya servo requirements?
Old 02-28-2003 | 06:50 PM
MrDHEJ
Default Freya servo requirements?
Originally posted by Dazzler
MrDHEJ, I would go with the 9252 on the elevator, and ailerons. 9204 or 9206 on collective, and you will be fine. You dont need more speed than the 9252's put out, but the added torque on the collective is great to have. Consider the Hitec 525BB on the throttle, it works great, and then your 9253 on the tail. I have this setup on both a Freya/YS80, and a Raptor 70 with no problems. Daz...
Ok, here is what i'm going to go with then. S9252 on Eleavator, Ailerons, and throttle, and the S9350 on the collective. The S9350 is rated at 139oz 0.12sec speed, which is more speed and torque then the 9206. That should be plenty of torque and speed for the collective.
This is probably way overkill for this heli and myself, but i'd much rather have to much then to little. Normally i would just throw Hitec 5945's "152oz 0.16sec" on everything and forget about it, but it's been 5 or 6 years since i've used futaba servo's and thought i'd try them out again.
Hey Daz, where bouts in ohio you live? I used to live in the Columbus / Amanda area some years back. I still go up there quite a bit still to visit family.
