RCU Forums - View Single Post - Synergy 90 Flying Reports: Post your experience flying here
Old 03-27-2003 | 03:58 AM
BocaBen
Default Found the hinge slots
OK, spent some more time poking around to find the hinges slots and finally found them. In case someone got into the same trouble, here are the locations:
- elevator, from the tip towards the center: 15, 70, 130,180mm
- ailerons, from the tip towards the center: 25, 148, 267, 386, 503, 624mm
Those are roughly the center of the hinges, a good spot to stick the x-acto in and work your way up and down till you reach the limit.
Jim, thanks for your help.
Ben
