RE: need some beginner tips-stable hover
I don’t know if you looked at all aspects of the Axe. I mean RTF, yah it comes completely build and you get a radio, that doesn’t mean it will fly when you take it out of the box.
I had to balance the main blades and set the tracking. I also had a problem with the fly bar paddles. One was warped so it was replaced. Also make sure they are both parallel to the swash. Make sure the distance between the paddle and the stabilizer control hub is exactly the same. Being out of balance there can cause the rotor to move in unexpected directions.
And by all means, practice, practice, practice.
Jake
