RCU Forums - View Single Post - need some beginner tips-stable hover
Old 05-26-2007 | 09:28 AM
alienteabagger
Default RE: need some beginner tips-stable hover
ORIGINAL: Whirley Bird
Make sure the blades are not to loose.
I tighten mine so that when I grab 1 blade it won't move in the grip from the weight of the heli.
Vegas/
On an Axe CP that is a very VERY bad thing to do. You want the main blades to be on the loose side. Tight enough so that they will stay in place when you tilt the heli on its side but loose enough so that if you shake the heli they both drop to the same level. On a bigger heli having the blade grips tight apparently is a good thing. This I know becuase my TRex doesn't like loose blades.
