RCU Forums - View Single Post - Shinden Build
Old 05-28-2007 | 11:50 AM
Jetpilot12
My Feedback: (19)
Default RE: Shinden Build
Mounting the landing gear. As you can see the holes are not drilled to mount the gear to the gearbox.
Cut a small square of paper and tape it to the gearbox. Then, using a punch find the holes. Place
the gear over the paper and trace it out. Remove the gear and match up the paper with the gear and mark the
holes with a marker. Drill the holes for a perfect fit.
ID:	692928   Click image for larger version
ID:	692929   Click image for larger version
ID:	692930   Click image for larger version
