RE: Whats wrong....?
Dave, If you are trying to connect to a JetTronics unit you will need 3mm line going into the metal Festo type fittings in the valve, instead of the usual 1/8" line found on most retracts, etc. That's the reason it feels like the fitting and line are too loose.
Richard
