RCU Forums - View Single Post - APC props
Thread: APC props
Old 05-28-2007 | 06:50 PM
GrahamC
Default RE: APC props
Cool Larry, thanks for sharing.
On Jim Bookers web site is a picture of how someone built a proto using a Profi which has a radial mount. There is always a way without having hack up the engine.
Looks like you used a bladder tank of some kind or was it straight pressure?
ORIGINAL: Larry Driskill
I think my plane was (is) about 7 ounces. Were I to build another I would shoot for 4 to 5 ounces as I was not getting to speed nearly as quickly as the fastest dudes at the Nats that year. They were turning over a hundred and I was going about 90.
Here are some dusty shots of the plane. Toad, note how the mounts are notched for the Cyclon. I used a stiff, thick nacelle to make up for the rather thin mounts where I notched them.
