RE: What should I use!!!!
Instead of digital or analog you probably mean PCM vs FM....I would use a JR 945 PCM rx, or if you can afford it a Weatronics rx...The JR 945 PCM rx is a dual conversion rx, where as the JR 955 PCM rx is a single conversion receiver. Both will be excellent---I prefer the 945 dual conversion PCM rx...
Kevin
