What should I use!!!!
My Feedback: (12)
TN
Hello gang-I am in the process of purchasing an MB-339 with a Wren 54II. The plane has Hitec digitals for servos, and had a Futaba PCM Rx. The jet will not come with the Rx. I will be using a JR 8103. Do I have to use a digital Rx, or can I use a good analog Rx?
My Feedback: (85)
Instead of digital or analog you probably mean PCM vs FM....I would use a JR 945 PCM rx, or if you can afford it a Weatronics rx...The JR 945 PCM rx is a dual conversion rx, where as the JR 955 PCM rx is a single conversion receiver. Both will be excellent---I prefer the 945 dual conversion PCM rx...
Kevin
Kevin
