antenna placement
I routed mine through a piece of fuel tubing down to the bottom front of the frame, then through a nylon pushrod tube through the holes in the struts (had to drill them out a bit). I then ran the tube along the tail boom support.
I have read warnings against that (glitches) but have not experienced any in many flights. Just don't let the antenna touch the tail boom or support.
Hope this helps.
