RE: Peakmodel Extra 260 25%
I had to add weight to the tail. Spacing from the firewall to the thrust washer was 5 1/4 inches. I am looking at moving the rudder servo in the tail. This should give me the cg i am looking for without adding weight and also give me the chance to move the cg back even further if i need to. The only problem is if I use the extra space in the tail for a servo the two servos will touch each other and will not fit. It does look like i will be able to cut a hole for the rudder servo just above the existing position without any problems. No big deal but a little more work than anticipated. But doing this will mean droping and easy 3 onces.
Rick
