ORIGINAL: jmodguy
I can provide the outlines I made for the 5 forward formers if you are interested. They go in the same location and use the stock Ziroli assembly crutch for alignment. I am in process of making a cowl that looks more like a Zero cowl. I have never done this before so I am not rushing into it. Don't want to do it twice. When I get it I will try to make a mold so I can make more than one. As for the rest of the Ziroli Zero it is pretty close. The canopy is good too. The wing is obviously for the A6M5. The horiz stab needs to move about 1/2" forward because the rear of the elevator should be in line with the front of the rudder. There are mods that need to be made to the control surfaces to make them more scale, but I'm sure they work quite well as designed as Nick is one of the great designers. The nose is a bit short and should be about an inch longer behind the cowl.
The ISBN number for the hardcover Maru Mechanic book is 4-7698-0635-3. The online store I got these from will only deal with Japanese. I have in-laws in Japan that they can ship to so I guess I am cheating. You may be able to find them on e-bay.
Jeff
Hi Jeff, i started building my ziroli zero and finished cutting all the fusalage formers, can you desribe the changes you made to the front formers ? and, if you can, post the outlines of these formers.
Thank you veryu much.
Raviv.
