ORIGINAL: Ravivos
Hi Jeff, i started building my ziroli zero and finished cutting all the fusalage formers, can you desribe the changes you made to the front formers ? and, if you can, post the outlines of these formers.
Thank you veryu much.
Raviv.
Raviv,
I do not currently have them in a digital format. I can try to get it done this weekend. The changes are pretty big. The top of the forward formers has been raised some, and allowances made for the gun humps. I also located notches for the scale locations of the stringers that go through the cockpit. I used 1/8" by 1/8" spruce for these stringers. F-4 (I think) is almost eliminated except for the lower part. This is to allow for a cockpit floor in a close to correct location. Using the plastic model I marked where the holes in the formers are and their appropriate sizes. The forward 6 formers are modified, not 5 like I mentioned previously.
Jeff
