RCU Forums - View Single Post - Zero help
Thread: Zero help
Old 05-30-2007 | 05:50 AM
Ravivos's Avatar
Ravivos
Default RE: Zero help
ORIGINAL: jmodguy
ORIGINAL: Ravivos
Hi Jeff, i started building my ziroli zero and finished cutting all the fusalage formers, can you desribe the changes you made to the front formers ? and, if you can, post the outlines of these formers.
Thank you veryu much.
Raviv.
Raviv,
I do not currently have them in a digital format. I can try to get it done this weekend. The changes are pretty big. The top of the forward formers has been raised some, and allowances made for the gun humps. I also located notches for the scale locations of the stringers that go through the cockpit. I used 1/8" by 1/8" spruce for these stringers. F-4 (I think) is almost eliminated except for the lower part. This is to allow for a cockpit floor in a close to correct location. Using the plastic model I marked where the holes in the formers are and their appropriate sizes. The forward 6 formers are modified, not 5 like I mentioned previously.
Jeff
It sure sounds like a major change...
the gun humps can be formed after the balsa sheeting is glued to place, using a block of wood.
I guess i have to see the changes you made in the formers in order to be able to visualise it.
Thank you for your input... please post some pictures of your build...
Raviv.
