RCU Forums - View Single Post - Comp ARF Flash update
Old 05-30-2007 | 06:09 AM
  #441
jstok
Default RE: Comp ARF Flash update
No issues here running p80 with full bypass , vents in bottom ,just coated the surface with BVM paint and foil over leads 'just in case', As Ian says running on the ground is worse case ,just seems to be warn to the touch.I did remove tailplane to have a look but all ok.
