RCU Forums - View Single Post - Cg issues
Thread: Cg issues
Old 05-30-2007 | 12:07 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Cg issues
Ok, DO NOT use that dimension, that is for the CMP model.
However, yours is only 3" shorter in the wingspan, so it will be close to that anyway.
I would give an educated guess and say that if you balance it in the 75 - 80mm range it should fly well enough for you to decide from there if you want to change it.
