RCU Forums - View Single Post - stuck in a sticky mess
Old 05-30-2007 | 09:25 PM
rlipsett
Default RE: stuck in a sticky mess
med ca for filling small gaps, a good all around building glue,sets in a few seconds so be quick with positioning. Thick ca for when you need time to pin and adjust parts before the glue sets. Wood glue gives good hold it soaks into the wood and bonds really strong and does not give off vapors that ca glues do that you will eventually become sensitive too. 5 min epoxy a good fast setting epoxy that does not form deep strong bonds due to the fact that it sets before it can be absorbed too deeply into the pieces. The longer the set time the stronger the bond within reason, anything over 45 minutes is not going to give you much more strength.
