RE: Need Programming Help
I for one wouldn't use gear as my mix......I'd use Aux 3 and set it up as dual elevators. You can then reverse the servo through your radio or re-reverse it since the servo is already reversed.
As far as getting it exact......you may be stuck using a matchbox....sometimes its the only way
