RCU Forums - View Single Post - kadet senior tail dragger question
Old 05-30-2007 | 11:58 PM
Pilgrim
Default RE: kadet senior tail dragger question
Kadet sr.............you guys drop stuff? I have my kadet sr set up so I can drop 48 8 oz soda cans....MT....it is really something to see all that stuff coming down, it's hard to keep flying the airplane. I put a dowel thru the fuse forward of the le of the wing on the bottom, extending about 10 or 12" out each side of the fuse & attach 4 dowels, each with 12 soda cans, put 1/2" holes in the cans & slide them on the dowels. The dowels go back under the stab with a mount on the bottom of the fuse holding the dowels with #64 rubber bands , & a servo mounted on the bottom of the fuse just back of the nose wheel. When you pull the servo arm forward it releases the rubber bands under the tail & the back of the dowels drop away & it chucks the cans off.
4 decks of cards look good coming down too............. pilgrim
