Of course!! I always go to the Loveland event.
Maybe I'll have my 30% Extra done by then.
I've only been working on that ARF for a year now. [
A lot of the guys at our field did switch to Futaba when we started having JR RX problems. They seam to be doing alright now.
I'm switching to my Aux channels right now and will try that. I think these servos have the little adjustment screw on the pots. If you remove the horn screw--you can see a tiny screw down inside that can be used to mechanically center the servo. I just talked to a friend and he told me to get all my subtrims to ZERO. He said that will help my mix. I need to check those servos and see if they are mechanically adjustable.
My elevator linkages are within microns of each other. Same length on both sides.
If I can adjust the pots manually and get my servos centered at neutral--maybe this will work.
Fingers crossed. [sm=tongue_smile.gif]
