RE: Getting fuel through the YS110 when starting for the first time...
I use hemostats to clamp shut the fuel line after fueling . I've plugged the pressure line. Then I take a small hand pump (retract pump, football pump etc will work) and put a couple of psi into the tank via the fuel line. Plug the line, remove the clamps. Voila !!
[link=http://www.hobbytool.com/index.asp?PageAction=VIEWCATS&Category=13]Hemostats cheap here[/link]
