RE: MONOKOTE
Of course, it may not stick as well the second time.
Make sure the area is CLEAN before you peel the old covering off,
Something else you should know: While "MonoKote" is a brand name, it is also a generic term like "Band-Aid" or "Q-Tip"
There are different brands of covering, some will come off and go back on easier than others. Usually, heat will help you remove it.
