RE: TX power loses!
You could have a broken solder connection at the on/off switch, a bad or corroded connection to the battery, etc.
Does tapping on the radio near the power switch, battery compartment, charge jack, trainer jack, etc, cause a loss of power?
Could even be a bad internal cable connection, or broken solder joints/cracked circuit board around any buttons or switches on the circuit board.
