RCU Forums - View Single Post - Removing Glow Fuel Residue
Old 06-01-2007 | 12:32 PM
opjose's Avatar
opjose
Default RE: Removing Glow Fuel Residue
The amount of time varies upon how much deposits there are on the engine.
Usually I place the engine in a small plastic pan and then cover it with DPD.
I let it sit for 5-15 minutes then use a metal brush on it to loosen the stubborn stuff.
Again I cover it with the Dissolver and let it sit longer.
On occasion I will rinse it in HOT water ( Yes I know... ) and reapply as needed.
Once the engine is clean I first flush it out with hot water, followed by a generous amount of WD 40... and then it is in turn flushed with alcohol followed by glow fuel to get out any vestiges of remaining moisture.
I let it sit for a day, then I flush it out with more glow fuel...
I've even used DPD on the interior ( cylinder head open and removed ) of a few old second hand engines to get out some stubborn build up. The engines have run well after the rebuild.
