RE: Removing Covering
Hi LT-40,
How are you tring to remove the covering at present?
Is it a open structure airframe or solid, ie. sheeted in balsa.
Is the covering one of the heat shrink plastic coverings, or something else.
If you could post a bit more info it will be easier for people to advise you.
Cheers,
