RCU Forums - View Single Post - Glow engine tuning help.
Old 06-01-2007 | 05:45 PM
Big feet's Avatar
Big feet
Default RE: Glow engine tuning help.
ORIGINAL: bruce88123
Do NOT waste your money on a temp gun. With the prop wash over the head you will never get a relaible reading anyway.
I second that, 17 years flying and never used one. I don't even know any plane guys that do.
Follow the advice given above by Piper_chuck to tune your engine, it is all done by listening to the sound and hence RPMs.
Once you get the feel for this it is quick and accurate. Every engine will need adjusted ever so slightly each day you go flying. These little engines are effected by changes in the air temp and humidity. Also, if you change fuel brand/mix or buy new fresh fuel after running on old stuff, you will need to check mixture.
Car guys use heat guns, but they don't have big windmills on the car.
happy flying
