ORIGINAL: seedo
hello:
i would be so greatfull if u can answer me these questions:
- what is the balance plug in the battery when i should use it?
- amd what mah means and what is good for.?
- what is good for edf planes what fan is good and what motor?
- how to use smart charger 2500?
thank u
Seedo
It sounds like you are asking questions regarding an all electric aircraft. Check over in the "E-Flight Power Sources" discussion forums here:
http://www.rcuniverse.com/forum/forumid_126/tt.htm
Before you spend any more time please consult some folks with more experience with electrics. From your question regarding the balencing tap it sounds like you have a lithium polymer battery. If you don't understand what you are doing you could inadvertently damage your battery or worse. Lithium polymer, also called Li-po, can store a significant amount of energy. These batteries are safe to use in this hobby, if you understand what you're doing. A damaged Li-po can potentially catch fire if it is not handled properly.
The electric flight guys can help answer all your questions. Most folks in this particular forum work with glow engines.
Cheers!
