RCU Forums - View Single Post - How to make sure engine is put on straight?
Old 06-02-2007 | 06:08 PM
bruce88123
Default RE: How to make sure engine is put on straight?
From a fixed point at the tail measure forward to a prop tip (prop held EXACTLY horizontal and use same point on tail centerline for both measurements). Distances to prop tips on each side of fuse should be equal. Use a measuring device that does NOT stretch when doing this. Point on tail not critical as long as on centerline but the further back the better.
