RCU Forums - View Single Post - Spinners
Thread: Spinners
Old 06-02-2007 | 08:05 PM
opjose's Avatar
opjose
Default RE: Spinners
Heh... my aluminum backplated "distorted" when I tightened it to overcome the constant loosening that happened with it.
It bent then cracked.
Luckily I caught it before attempting to start the plane.... as I decided to take the cowl off to check something else...
Had I been in the line of fire for those metal fragements, well.... on this the plastic pieces would have caused less damage.
You can have problems with both materials as I found out the hard way.
Aluminum spinners are in no way immune to the same problems.
