RCU Forums - View Single Post - Servo Chatter on Field Test
Old 06-03-2007 | 11:38 AM
opjose's Avatar
opjose
Default RE: Servo Chatter on Field Test
You could have another local emitter.
WiFi frequently causes my planes to go nuts, when I turn them on in my house. ( Spread Spectrum is not subject to all of this... )
Usually the RX locks on to your TX if the signal is of sufficient strength.
As others have pointed out it does sound as if the TX is not putting out a strong signal, but you should also double check that you are not getting interference of some sort...
