ORIGINAL: felixone
Opjose,
I think you might have confused me...
As I understand it a servo has a define range of movement. If I am currently moving through that entire range, how can I "increase" this using my TX? I know that I can limit the range the servo moves, but wasn't aware that I could increase it outside of it's default range. It is my understanding that this is how high/low rates are setup. Basically high rates are defined as the full range of movement. You then program the radio to only move X percent when low rates are activated.
Could you please explain this a little more for me.
if you have a computer radio you can adjust your EPA (end point adjustments) to move it out a little more or decrease it. Along with the adjustments on your servo and control horn your desired setting
