RCU Forums - View Single Post - Newbie Question
Old 06-03-2007 | 08:28 PM
opjose's Avatar
opjose
Default RE: Newbie Question
Like he said...
A better option is if you can, use the computer radio to set the end point adjustment ( or range of travel ) to take the servo to it's extremes...
e.g. 150%
That will give you more movement of the control surfaces w/o needing to move the linkages further out on the control horn.
In so doing you gain better holding power, less current usage, and less chance of stripping a servo gear.
There are articles about this here and many of the magazines that go into this in detail.
I believe FlyRC had an article about servos in their last issue where they also went into this.
