RCU Forums - View Single Post - Need help CP
Thread: Need help CP
Old 06-04-2007 | 12:40 AM
mrasmm
Default RE: Need help CP
if he's got it setup well and he can fly it, then it's probably good to go, but with that said...
add some weight to lower the cg like a bigger battery super skids or training gear. Also make sure the weights on the flybar are all the way out, and you could even have 2 sets on there to dampen the effects. You can also move the swash links in a hole or so on the servos to tame down the side to side motion =)
If you've adjusted a bunch have your friend try to fly it again and see what he can do with it.
