RCU Forums - View Single Post - Hinge Gap Question
Old 06-04-2007 | 07:46 AM
bkdavy's Avatar
bkdavy
Default RE: Hinge Gap Question
Strips of monokote will work fine. Just be careful when heating with the iron, and use as low a heat setting as you can to activate the glue. Many ARFs are covered with much lower heat coverings, and the heat required for monokote can cause problems.
Brad
